I have a peplink balance 30 and a cisco wlan controller connected to a switch. I switched DHCP Server to cisco wlan controller and disabled the one on the peplink balance so I can take off some stress. Since I did that, every vpn connection to the peplink pptp server fails. Can someone please help me identifying why this is happening?
As long as the cisco is on the LAN of the Balance and you are on 5.x firmware or above you can use the cisco to hand out IP’s to incoming PPTP clients.
If you can confirm the cisco is on the LAN of the Balance and you are on 5.x firmware or above and not working, open a support ticket here: http://cs.peplink.com/contact/support/
