Passwords?
I am able to log into InControl, but I can no longer log into my router as it rejects my password. I am using a MAX BR1 MINI, FIRMWARE 8.3.0 build 5256.
If you can log into incontrol, you can either use remote web admin to connect to your device and change the local password, or you can edit system device settings at the group level and set a password there which will get pushed out.
