Papwave MAX BR1 Mini and SIM card?
I bought a used Pepwave MAX BR1 Minmi and tried to use a data only AT&T Sim card that works great in a NetGear Explore hot spot and a WG3526 router with sim card slot. But in the Pepwave I can’t access the 192.168.50.1 in my browser (Google Chrome). Is it possible this router does not support AT&T?
Some plans only work on specific devices and/or require a specific APN to be set.
Check with your provider.
Understood the need to change VPN. But I need to get to the menu to do this. I’m told it needs to be changed to “Broadband”
Under cellular on dashboard you can go to apn and set to manual.
The problem is I cant access the dash board
Hi!
I suggest you factory reset the router - find the product manual, update the software and then see what happens.
