Outbound policy to force IPSEC outbound from LAN clients over PepVPN not working
What am I missing here?
Have a deployment of a BR1 with a PepVPN via a Cloud hosted Fusionhub.
All remote client traffic is being sent via PepVPN. All client traffic is successfully redirected except IPSEC traffic from a VPN appliance on the LAN using UDP 500 which no matter what is being redirected via Cellular WAN and not PepVPN.
Assumed it was NAT-T service passthrough, but on or off traffic still goes out over cellular…
Ideas?
If I use ‘send all traffic to’ UDP 500 is routed correctly over the PepVPN - which is fine and gets me out of the mess but is there a way to configured this with individual outbound polices (which is my preference)?
Can’t check now - but maybe this works if using Expert mode in outbound polciies?
This is weird.
  1. Enforce outbound policy used ? If priority used, did the “Terminate Sessions on Link Recovery” enabled ?
  2. Did you try to before reboot the device (after disable/enable NAT-T service passthrough) ? This will make sure all session cleared.
Tried Enforced with “Terminate Sessions on link Recovery” then tempoarily disabled the LAN ports and re-enabled them to make sure all sessions had to be rebuilt
Couldn’t reboot the device as direct internet access (over wifi) was in use and needed to be available, but did disable LAN ports and re-enable them.
Maybe I just had a peculiar situation at the time. Its in and working now (for 5 months or so ) so no need to change anything for now. If I get the chance to test out of hours I will.
