When you set up outbound policy rules, I understand that the router starts from the top rule and works its way down. If it matches the very first rule (in case, a Least Used rule for ALL outbound traffic), does it stop processing rules? The reason I ask is that I’d also want it to process the HTTPS_Persistance rule, which also matches all traffic.
So, does the router stop processing rules when it finds a match, or does it keep going adding rules that match?
If the former, then I guess you can’t enforce an HTTPS_Persistance when doing any kind of custom load balancing (like Least Used)?
If the latter, then I guess you just have to be careful of not creating conflicting rules, or would it just used the last matching rule if they are in conflict? ie. you had two rules which applies to all outbound traffic, one a Least Used, the other a Weighted Balance, it would just use the bottom one in the order?
Your manual should be updated to incorporate this info…
