I have an Peplink Balance 310 and i am connecting to a relay router at another location using a fixed public IP address, however i have two additional WAN connections that i want to use users to use for browsing and i want only that fixed IP address to connect to the Relay smtp server…I have tried numerous configurations but it still seem to try to connect using the other two WAN connections…any ideas?
You just need to create an outbound rule for the type of traffic you want to send to this IP address. You can enforce it over a particular WAN or use Priority with that WAN as the highest.
If you need help configuring it, feel free to give our support line a ring or start a support ticket via our website.
