OpenVPN WAN throughput?
Is there a chart anywhere showing what OpenVPN WAN speed to expect with various models?
On a max-transit cat-18 I’m only seeing 15 mbps until the max transit cat-18’s cpu is maxed at 97%.
The chart says that PepVPN (SpeedFusion VPN) speed would be 60 mbps with 256 AES encryption, so the OpenVPN efficiency seems much lower in terms of CPU required to run it.
Is this normal/expected?
