OpenVPN firmware 8.3.0
After upgrade to 8.3.0 on MAX BR1 MK2 under Advanced > VPN appeared OpenVPN option.
Trying to setup MAX BR1 MK2 as OpenVPN client.
Loaded profile, everything is ok. Can ping both sides. No problem here. Routing works as expected.
But when I enable OpenVPN profile Pepwave web admin interface stops responding from the local network via HTTP/HTTPS. SSH does not work from local IPs. And even DNS. From remote side everything is ok (HTTP/HTTPS/SSH).
If I change some WAN settings on Pepwave, for example, enable/disable DNS over HTTPS, then HTTP/HTTPS/SSH/DNS works from local network, but does not from remote remote. If i disable/enable OpenVPN profile everything comes vice versa.
Why?
Any way to make it work?
Thank you.
Anyone?
I hope that’s not the way it designed to work.
Thx.
UPD:
It seems I have the similar problem .
But it’s unclear what the solution is.
Any chance to fix that?
UPD2:
Fixed in fw-max_br1mk2_hotspot_sohomk3-8.3.0s082-build5131.bin.
Got the firmware via support request.
