Running firmware 8.5.2 on my B One router, my OpenVPN connection (Proton VPN) has recently started to drop. This breaks most of my smart home devices as the VLAN they reside on has its connections routed through the OpenVPN WAN connection. Once the connection is lost, the router tries to reconnect - and it eventually does, but it takes a while. Listed below are some log entries showing this behavior.
I changed the Proton VPN server the router is connecting to, but that didn’t help. Next, I just tried re-booting with firmware 8.5.1. After the reboot the OpenVPN WAN was connected; we’ll see how stable that turns out to be.
Anyone else having problems or suggestions to resolve this? Thanks in advance for any help.
| Oct 26 16:43:10 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.14) |
| Oct 26 15:51:26 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 26 15:37:00 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.14) |
| Oct 26 14:45:28 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 26 14:08:20 | Port: Port 2 (LAN Port 2) status changed (link up, speed 1 Gbps Full Duplex) |
| Oct 26 14:08:17 | Port: Port 2 (LAN Port 2) status changed (link down) |
| Oct 26 14:08:14 | Port: Port 2 (LAN Port 2) status changed (link up, speed 1 Gbps Full Duplex) |
| Oct 26 14:08:11 | Port: Port 2 (LAN Port 2) status changed (link down) |
| Oct 26 14:08:08 | Port: Port 2 (LAN Port 2) status changed (link up, speed 1 Gbps Full Duplex) |
| Oct 26 11:29:26 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.14) |
| Oct 26 10:37:49 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 26 10:03:25 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.17) |
| Oct 26 09:11:32 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 26 08:31:30 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.17) |
| Oct 26 07:39:55 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 25 17:02:09 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.14) |
| Oct 25 16:10:22 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 25 08:06:19 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.39) |
| Oct 25 07:14:28 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 25 06:52:10 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.39) |
| Oct 25 06:00:21 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 25 05:31:00 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.28) |
| Oct 25 04:39:15 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 24 19:57:09 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.9) |
| Oct 24 19:05:21 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 24 11:37:50 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.12) |
| Oct 24 10:46:01 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 24 09:35:40 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.45) |
| Oct 24 08:43:47 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 23 20:56:05 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.12) |
| Oct 23 20:04:27 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
| Oct 22 17:23:58 | WAN: OpenVPN WAN 1 (Priority 1) connected (10.96.0.9) |
| Oct 22 16:32:12 | WAN: OpenVPN WAN 1 (Priority 1) disconnected |
