One Peplink's Wifi output as another Peplink's Wifi input.
Two networks:
One is mobile in an RV.
One is in a house.
The RV has a Peplink Balance 20X that has Starlink WAN and Cellular WAN bonded together when needed with Speedfusion.
The house has a less-than-reliable fiber line.
When the RV is parked in the driveway, I’d like to use the Balance 20X’s wireless network as a second WAN source in the house through WifiWAN so that I can Speedfusion bond it with the unreliable fiber.
What Peplink device would be my best option to speedfusion an ethernet WAN with a wifiWAN?
Also: Is there any reason not to have a Speedfusion bond inside of another Speedfusion bond? (i.e. the starlink+cellular speedfusion’d are the WifiWAN for the in house fiber+wifiwan Speedfusion bond)?
I feel like I’m missing something obvious and/or I am going about this all wrong. Thoughts?
Cheers and Thanks,
Ed
p.s. there is no option to run an ethernet from the Balance20x. I can only really use it’s wifi signal.
p.s.s. The house does not have cellular service. The RV gets a little bit thanks to a parsec antenna and strategic parking (-:
You could just use another Balance 20X.
I wouldn’t run a tunnel inside a tunnel, it will work but you’ll have a lot of overhead. Just setup an outbound rule on the RV Balance to forward traffic from the House Balance straight over the Starlink connection and run the speedfusion tunnel from the house Balance.
Do you have a second peplink in the house? If not you could add one and then use wifi-as-wan on that 20x to connect to the rv broadcasted wifi. Let me know if you need help setting it up we are a peplink partner and call assist you with that.
