Is it possible to get email, text or push notification of LAN device going down and coming back online?
I am using the MAX BR1 ENT modems.
For example, I have used UpTime Robot to monitor if devices, web pages, etc are online. I don’t think I can do this in this situation. Is there something built into the modem or in InControl2?
If not, what could work for this?
Thank you,
Adam
In IC2, there is an option for LAN Port UP/Down, but it is only for:
“Require Balance One, One Core, 210/310 HW4, MediaFast 200, MAX HD4 LTE, HD2/HD4 LTE with MediaFast, 700 HW3, HD2 HW5, Surf SOHO MK3; and running firmware 7.0.1 or above”
I am really hoping this would do it and this feature comes to the MAX BR1 ENT modems.
Hello @Adam_Van_Spronsen ,
You will unlikely be able to do this in the Pepwave MAX BR1 ENT due to the model’s age using an older generation of ethernet chipsets. This model is now discontinued and superseded by new models; you may need to upgrade to a newer unit with the LAN Chipset capability you seek.
Alternatively, if you have the space, a Pepwave SD Switch on the router’s LAN could also offer your desired functionality.
Happy to Help,
Marcus
