No Cable Detected on WAN Port
I am having issues with connecting to the WAN Port of my Pepwave Max Transit Duo.
It seems like the port on the router is flaky as I have had success with a little nudging of the wire and yet mostly I am not able to get it to recognize. My goal is to have my Starlink connected via DC without router (hence no Wifi WAN). For testing I have run a Cat5e cable from house and when it connects it works. A simple movement of the wire and I lose connection. Also, plugging in and out and such does not reconnect it – I have not figured out the “magic” alignment of pressure to connect.
I updated the Firmware and am up to date at 8.3.0.
Any thoughts on what to try and guidance?
Is it possible that that RJ45 connectors that I’m using are at issue with the port?
Scott
