No bandwith pepwave MAX HD4
Hi
my pepwave Max HD4 is connected via a sim on a 4G+ LTE network (B3 & B20)
When I perform a speed test (wired connect) I do not exceed 50 Mbps on the download. Normally I should be able to go up to 160Mbps. That’s what I get with my iphone placed next to the pepwave.
The reception level is very good , it is located within 500m of the operator’s antennas.
Does the Max HD4 make carrier aggregation?
How can we check?
Thank you
Bests regards
