Next Gen Max Transit
I’m filing this under Feature Request, but it’s actually a future product / hardware request. On the Max Transit 5G, could you please consider giving it more CPU / routing throughput / SpeedFusion throughput on the next iteration. I have a Cat 18 Max Transit and I’m not upgrading to the 5G version mainly because I’m already hitting the limits of the device with 4G - 60Mbps encrypted / 100Mbps un-encrypted / 400Mbps routing - although I’ve only seen about 160-170Mbps routing with my set of features turned on. I’m hopeful that when you create the next 5G version, it will have more CPU so I can use more of the available bandwidth.
Have a look at the BR1 5G…
