New Max BR1 Mini Speed Issue
First time user here. Bought max br1 mini off amazon and got verizon sim with 150 gig monthly limit and first time using it will not get above 1-2 meg download. what am i doing wrong?
Many of the VZW plans are throttled, some as low as 10 mb/sec, Here’s what I would do: (1) update the device firmware (if needed) and then check and see if the modem firmware is current at https://192.168.50.1/cgi-bin/MANGA/support.cgi (if you have not changed the device’s address); (2) check and see if your plan is throttled and then (3) go to the vicinity of a Verizon cel site and check the performance there. You may want to repeat the second step at another location.
Your report is atypical and I think some more information should be collected before a conclusion is drawn.
