Hi, I am looking for a way to run both a layer 2 & layer 3 pepvpn between the same pair of Max routers. These are 2 physically seperate networks (that must remain that way) at each end point, and would be accessed from seperate vlan tagged LAN ports on each router.
At present multiple pepvpn profiles cannot have the same remote ID. Is there another way of achieving this without a 3rd router at one end point?
The layer 2 VPN does not need to be pepvpn, but it needs to pass multicast and I have had no luck doing this with IPSEC or GRE on the peplinks.
Any advice would be appreciated.
Regards,
Peter
