Our Customers WLAN consists of BLC710 and 14 AP Ones and it is used for multiple purposes. One of departments asked us to create a SSID that would work on different channels than other SSIDs. All SSID have to be broadcasted from same AP, but using different channels.
I tried to achieve that by using AP Profile settings, but channel selection affects all SSIDs applied to one AP profile. Then I created separate profile for channel-isolated SSID, but it is not possible to apply two AP Profiles to one device.
Do you have any idea on how do I fulfill their requirements? Maybe allowing more than 1 AP Profile to be applied to AP would be a good solution?
Jakub
