looking for MTBF numbers on Peplink products - specifically Balance 20X and 24 port SD switch.
I cant seem to find any information in the datasheets. Anyone have this information?
br
Asger
br
Asger
Hi Asger,
I have sent you information via e-mail.
Hi, I am also looking for MTBF numbers on Peplink products. I couldnt found any information in the datasheets. Can you please also send me the information?
Thank you very much.
Br
Karan
Hi Karan,
I suggest you contact your reseller or distributor they should be able to provide this information.
okay. I will do that. Thank you for your quick reply.
