I have read a lot of error here on your forum regarding SMTP latency problem. we also encounter it now. when we are testing the incoming packets the SMTP packets shows a lot of delays that causes the TCP session close in 5 - 7 minutes. LB harden TCP traffic overheads in an effort to stop all potential high bandwidth traffic.
Is there a work around for this kind of happening?
This is definitely abnormal behavior. Please open a support ticket here for support team to check.
Please provide detail info for the issue in the support ticket
Previously SMTP working fine ? Any changes make for the device recently ? (Latency can be cause by other influences)
The issue happen all the times ? or intermittent
Please provide also your testing info for the SMTP connection:
- Packet capture for the SMTP connections
- Others
- Can you explain the description given in previous post ?
" LB harden TCP traffic overheads in an effort to stop all potential high bandwidth traffic "
