I would like to have more control of the health check settings. In particular I would like to be able to increase recovery retries to a much higher number than 20. I am currently doing the health check every 5 seconds, 20 recovery retries means the connection simply has to be stable for 2 minutes before switching back and honestly I don’t think i’d want to switch it back unless its stable for at least 30 minutes. In fact just let us type the number of retries in there.
Understood your concern. Anyway please take note if the primary WAN stable for 29 minutes but fail again at 29 minutes 1 second, then you have to wait for another 30 minutes. End up it is possible to take few hours to fail back to primary WAN link. Is this acceptable?
yes, just let us type the number of retries in the box.
I want to be able to set Health Check Retries to 2 as well.
Still need more health check settings, this is still an inconvenience to have no way to test connection frequently AND require long durations of stability before restoring the connection.
