Monitoring Speedfusion Capacity by UDP Package Drop Rate
we had a discussion today, if it is possible to get an alarm if a certain amount of udp packages is being dropped from the speedfusion tunnel.
We are planning to send a udp stream and make sure to get an alarm when quality drops due to an overloaded mobile network or else.
So one criteria would be exzessive package loss.
Any idea?
Thanks a lot
Kind regards
Johannes
You could do this with custom code and the Local device API.
Using it you can get stats for each tunnel which include packet loss.
Hi Martin,
that`s a good idea.
Thanks a lot
Johannes
