Hi
Is there a way to view what rate the modem is currently connected at? (asides from using a service like speedtest.net)
I have a BR1 LTE edition and wish to trial a few prepay SIM cards to determine which network I can get the fastest speed with.
Mike
Hi Mike, there is no way to see what rate the modem is connected at to the cellular tower. This is a dynamic setting that is controlled by the network and is dependent on RSSI, power levels, antennas, MIMO, etc.
OK thanks - there are many significantly cheaper units that display this data. I will put to the dev team as a feature request.
Cheers
