Mini flex module 1Gbps Ethernet
What are the odds of Peplink offering a 1Gig Ethernet mini-flex module that can be plugged into a B20X?
can I ask what would be the benefit ?, as the Balance 20X has Max throughput of 900mbps, and it already has a internal 1Gbps WAN port, would you want to use as a Backup 1Gbps Link ?
Andy.
I would guess that @steve_tx was wanting to have two wired wan connections.
I like the idea and it makes sense, but the miniflex is limited to 150mbps.
So then that throws out the ability to have a 1g port.
see this for more discussion on it.
https://forum.peplink.com/t/will-the-balance-20x-support-5g-on-the-flex-mini-expansion-module/31620
then why not use a USB to Ethernet adapter for the 2nd wired LAN ?, I use this for my 2 VDSL lines, and it load balance for me.
@AndrewStyblac4791 Maybe Steve was planning on doing that as well and wanted three, or he wanted the integrated look and thought that if it was a module it might perform faster.
