MIMO Cellular Modem with no WiFi or WiFi that can be disabled
I am trying to find a cellular modem with cellular MIMO capability that either does not have WiFi or that has WiFi that can be turned off, does anyone know of a product that meets those conditions?
TIA,
Steve
Hi @Steve_O_Brien .
If you are looking for a modem only (i.e., not a router which includes a modem), I would point you to the Adapter – several variants and no wi-fi.
If, however, you are seeking a router (which may or may not include wi-fi, although most do) I’d note that wi-fi can be completely disabled on all devices which include it.
If you can narrow your requirements a bit one of us can likely help you a bit more.
Thanks Rick, I just need a Cellular modem that has an ethernet out. I will then pipe it through my network to my firewall. I would like it it to have 4x4 MIMO external antenna inputs.
WiFi can be turned off on any of the Peplink routers…
What about an HD1 Dome
why wouldnt it be able to? the software is universal, right? drag the wifi want to disabled, disable the LAN AP. right?
How about the router of your choice placed in IP Passthrough mode? Works well.
