We currently use Peplink Balance One and AP One Enterprise for our office. However, on the opposite side of the building is a conference room we frequently use. Right now the signal on the opposite side of the building is less than ideal.
We also have the AP One 300m (not being used right now) that the AP One Enterprise replaced and the embedded wifi from the Balance One (also disabled).
I’m open to suggestions on the best way to provide a solid signal across the building using these Peplink pieces. Thanks.
As per what @kgarvey has mentioned, it depends on the distance. If you can still “see” your Wi-Fi while inside the conference room, you should see an improvement by deploying the AP One 300M in the same room to extend your Wi-Fi coverage.
Right – but as I mentioned we don’t have an ethernet port in that room since it isn’t our room. We have a somewhat flaky wifi signal, and we want to extend it to better cover this conference room.
I can see “see” the WiFi while in the conference room, but the signal seems to fade.
The AP One Rugged appears to have almost 75% more coverage than the AP One Enterprise (680m vs 400m).
Is there any concern with deploying this in a typical office environment vs outdoor or in a “rugged” environment? If not I will give that a go instead.
AP One Rugged is our go to for range indoor. Supper reliable and they just perform. Same with AP One Enterprise but we only use these for ceiling mount situations.
