I have a Balance 30 LTE. My primary ISP just upgraded speeds from 150Mbps to 200Mbps. I was not seeing the improvement. After further investigation I discovered the Balance 30 has a maximum throughput of 150Mbps and that is where I am maxing out. I am not looking forward to having to start all over again on router configuration (though it looks like Peplink support might be able to convert the configuration file to another model). Do I have any options other than buying a new router with faster throughput? Any suggestions appreciated.
This is a hardware limitation of the Balance 30 and you will never be able to get more then around 150Mbps throughput. I recommend to upgrade to the Balance One or Balance 305 and our support team will be able to convert the configuration over for you.
