We will have 3 WANs ( 250M 50M and 10M ) and which models will work for us ? 380 or 580 or 710 or All of them ?
Where I can check the information about the maximum bandwidth per WAN port. Thank you for your answer.
Maximum per WAN speeds is base on the physical Ethernet WAN Ports speeds. Again, you have to take note for the router throughput that rated for the product model.
I would suggest you check with Peplink Local partner for the product model sizing as there are more things you need to check.
https://www.peplink.com/peplink-certified-partners/
