Max Transit Pro - USB-C Ports for Power
If the USB-C ports are used to supply power to the Max Transit Pro, when why are there 2 of them? Is there a use case where one would need to use both to supply power?
First thing of note is that these are USB C PD ports. Acceptable voltages are:
  1. 9V, 3A
  2. 12V, 3A
  3. 15V, 3A
  4. 20V, 3A
5V is not supported.
There are two so you can do hot swap. / prolong run time on connected batteries.
