How do I enable / view Real time GPS Tracking for the MAX Transit router?
Is it possible to view it in InControl2? If so where do I go? Because I have not seen it update the location at all. It only shows the location that it resolved from the ip address and hasn’t updated since.
You need to make sure GPS antenna is properly install for the device (Line of Sight facing the sky) and as long as the GPS signal detected the GPS fleet will automatically shown in the InControl2 device details page.
For more information, please refer to the screenshot below:
Regarding on how to check whether GPS signal is detected for the device, you can refer to the forum thread below:
Thank You
