I have had my Transit Duo LTE-A for about 8 weeks now and am having problems with it constantly crashing, or SSIDs not being visible, even though the AP reports it is up.
So I have it setup with 2x LTE SIMS (Verizon & Cricket), and usually connect to Marina or hotel wifi using WiFi WAN on both 2.4 and 5 GHZ. I have the inbuilt AP setup with 3x SSIDs. XXX-Dual, XXX-2G and XXX-5G.
One minute all 2 SSIDs are there, sometimes only the 5G and Dual are visible (seems to coincide with WiFi WAN on 2G Connecting) Other times only 2G is visible, sometimes neither is visible, but I can usually connect to the router via ethernet cable - or via remote web from InControl.
At other times it appears to re-boot spontaneously for no reason. Nothing in the event logs to indicate why.
I have tried the latest 8.1 firmware, the beta firmware and a previous 8.0.2 firmware.
I have tried deleting my speed fusion profiles and outbound policy stuff.
I have even done a factory reset and the just configured the basics, but it still crashes.
Any advice what to do next.
eg.
Dec 03 18:02:56 | Admin: admin (192.168.50.10) login successful |
Dec 03 18:02:54 | WAN: Wi-Fi WAN on 5 GHz connected to Zencity (192.168.1.146) |
Dec 03 18:02:51 | System: Time synchronization successful |
Dec 03 18:02:28 | System: Time synchronization successful (InControl) |
Dec 03 18:02:27 | WAN: Cricket connected to cricket (10.51.221.72) in SIM slot A |
Dec 03 18:02:22 | WAN: Verizon connected to Verizon (100.101.69.231) in SIM slot A |
Dec 03 18:02:05 | System: Wi-Fi AP Normal Mode |
Dec 03 18:01:38 | System: Started up (8.0.2 build 4407) |
Dec 03 17:59:58 | System: Started up (8.0.2 build 4407) |
Dec 03 17:51:05 | System: Started up (8.0.2 build 4407) |
Dec 03 17:43:12 | System: Started up (8.0.2 build 4407) |
Dec 03 17:38:20 | System: Started up (8.0.2 build 4407) |
Dec 03 17:36:56 | System: Started up (8.0.2 build 4407) |
Dec 03 17:34:58 | System: Started up (8.0.2 build 4407) |
Dec 03 17:33:14 | System: Started up (8.0.2 build 4407) |
Why did it reboot 8 times in half an hour?
