Got a Max Transit Cat 18 on Friday and am using it with T-mobile.
Strange thing I noticed today is that from a windows client, a tracert or winmtr shows only the max transit first hop and last hop of the destination. All hops in between are not there. I have not seen this before, and thought it may be a windows 10 issue, so I logged into the max transit itself.
From system, traceroute, I did the following traceroutes from the max transit, and it shows only one hop:
Connection: Cellular
Destination: google.com
Results
traceroute to google.com (216.58.193.142), 30 hops max, 60 byte packets
1 dfw25s34-in-f14.1e100.net (216.58.193.142) 70.670 ms 70.465 ms 70.278 ms
Destination: 8.8.8.8
Results
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 60 byte packets
1 dns.google (8.8.8.8) 45.529 ms 45.226 ms 57.258 ms
Destination: peplink.com
Results
traceroute to peplink.com (104.25.205.4), 30 hops max, 60 byte packets
1 104.25.205.4 (104.25.205.4) 51.357 ms 51.110 ms 63.160 ms
Has anyone seen this before with a max transit or t-mobile?
Edit: installed an AT&T sim, and Iām getting the same thing on AT&T in the max transit. So it appears there must be a setting in the max transit causing this. Any ideas?
With AT&T SIM installed, going to system, tools, traceroute on the max transit cat 18, the following is the result (all hops missing except for final destination hop)
Results
1 104.25.205.4 (104.25.205.4) 54.749 ms 66.563 ms 66.391 ms
