Max router supply voltage measurement
is the DC supply voltage measure in any of the MAX (BR1 in particular) routers? if so is there a way to display/interogate the supply voltage value?
I know this is an old post, but I’m curious about the same thing. We are using some Milwaukee batteries to power BR1 and BR2 devices and I’d really like to have visibility into the DC voltage. With this, I can compare the battery’s curve to the input voltage the MAX router is seeing and, in theory, do things based on this.
Hi Christopher,
in case you are talking about BR2 Pro, then it has analog input pin so you can measure the input voltage. Here you can find a discussion. Hopefully this helps :wink:
