MAX RF output for 3,4,5G
I need to get a combiner for hang a few Cellular devices off one antenna. What would the MAX RF output for 3,4,5G so I can calculate the correct combiner.
Ta
Do yourself a favour and don’t do this, you are setting yourself up for a world of pain - use discrete antennas for each device.
If it is a case of saving mouting space you could under some circumstances use a MIMO antenna to serve different radios / devices.
For example say you had 2x MAX BR1 Pro 5G which requires 4x cellular antennas per unit, you could use an 8 element MIMO antenna and connect 4 elements of it to each BR1 (assuming the antenna is suitably well designed with sufficient isolation between the elements - some are, some are not).
