Can you please recommend an aerial to be used with the MAX OTG4?
Because of its location in my server cabinet, 4G drops in and out, and I’d like to find a way to improve the signal.
Thanks!
Thanks!
Do you mean an antenna to connect to your LTE usb modem plugged into the MOTG? what usb modem are you using?
Hi Martin. Thanks for your reply.
I’m really sorry for wasting your time, but I thought the MOTG had the ability to attach an aerial, like the Peplink modems with the built-in SIM. Of course, they don’t, and I’m using Sierra Wireless USB modems.
I’m going to open another thread asking if any of the built-in SIM models support any Thai networks, as 4G LTE appears to be my best option here, and the MOTG doesn’t allow me to use an aerial.
Thanks again.
