Max-OTG speedfusion setup
Hi… I have had a Max-OTG with speed fusion connected to a Balance one. I am using 4 4G modems with the ORG and the Balance one is connected directly to our fibre service provider.
I have got all 4 modems up and connected and making a (established) speedfusion tunnel to the Balance one.
BUT I can’t even get a ping through!
I have tried a speed test in the status tab (works fine all four links carrying load…
I wondered after reading various posts if the Balance one needs a speedfusion licence too?
Everything is showing as online in In control…
I am trying to stream a single 2Mbps but if I have read the forums it now looks like the max - otg does not do bandwidth fusion (why I bought it in the first place!)… the wierd thing is that the marketing example of sending a stream bonded over 4 modems is exactly what I thought I wanted to do!
Can not ping not related to the license. Can you please check the followings:
  1. From MOTG end devices:
  • Can you ping Balance One LAN IP ?
  1. Please check Balance One end devices whether enabled with host firewall.
