I ordered 2 of these MAX HD2 units as a trial for an oil and gas application. The first unit was tested, worked well and deployed.
Six months later, I am now trying to test and deploy the second unit however I am unable to get the device to do anything. As soon as it powers on via POE the red LED is illuminated and stays on solid. With the VERY limited information available on this device from Peplink, it seems to indicate the unit is “Booting up or Busy” however the light does not change to green.
Good Afternoon
Can you try powering it with the PSU supplied with the unit rather than via PoE?
It could be the device is not getting enough power to boot up properly.
