I am trying to create site-site VPN using PEPWAVE MAX HD2 on both sites. The configuration requires 10 remote sites to connect to a local site. While each remote site requires only 1 IPsec VPN profile, the local site requires 10 such profiles.
However, I realised that I can create at most 5 profiles for IPsec VPN on the local site. Is there any get-around to fulfil my configuration.
Thank you.
