Hi there,
i am at the Hong Kong to testing the MAX HD2 and i using (THREE) 4G sim are not working due to can’t get the ip address, however i change to using Smartone 4G sim there are no problem at all, i need to find out that where the problem is?
Regards,
JJ
Hi JJ,
Can you share what is the service provider for these 3 Sim cards?
Can you share cellular signal info below for 3 Sim cards?
Hi TK Liew,
The problem may due to signal strength and noise level there. Please open ticket for us to check further when the unit is ready.
