Max HD 2 MediaFast Change SSD card? Cache Win updates?
Hello there.
Is it possible to replace the 120GB SSD card by a bigger one and is it possible to cache the windows updates and AV signitures?
Thanks a lot
I would suggest to contact Peplink local partner/distributor to test on the MediaFast caching efficiency. Please also talk to them for the custom Disk size requirements, they should able to help you to forward the request to the correct team.
Thank You :slight_smile:
