Max Br2 Pro SMA torque
Hi, does anyone know the talk setting for the SMA connectors on the max br2 pro?
3-5 inch pounds, without a proper torque wrench, basically finger tight then a very slight amount more with a wrench. When I say slight, I mean like maybe 5 degrees. It is very hard to judge torque with something that light, don’t hold the wrench at the end, hold it as close to the nut as you can, pressing with one finger would be okay.
For use in a stationary application, finger tight is fine. For on the road it is nice to have it just slightly more snug so it doesn’t vibrate off.
One trick you can use if you have a small digital scale around, press on that scale trying to put 3 pounds down on it with your index finger to get a feel for how little that is. Then try to press that hard one inch from the connector on the wrench handle.
Thanks. I’m about to buy a torque wrench hence needing to know what setting to get one because they seem to be fixed at that size with a wrench end
We use these: SMA Fixed Torque Wrench in Click Type 5/16 inch Bit that is Pre-set to 5 in-lbs
