Max Br1 Mk2 offline
I can reboot my Max Br1 Mk2 and within a couple of hours it’s offline and I have no wifi from it. And ideas?
Hi James,
I would check the Powersupply at first. If this is okay, then dismount everything from the device, networkcables, Cellular and WiFi Antennas (if you don’t use the Antennas out of the original packes).
If this also doesn’t help, then open a support ticket at Peplink or better your Peplink Partner
BR
Dennis
