MAX-BR1-MINI obsolete?
There is a message scrolling across one of your US resellers website that the MAX-BR1-MINI-LTE-US is obsolete, and Peplink is recommending MAX-BR1-MINI-LTE-US-T-PRM as a replacement. Is this correct? If so, will the -T-PRM be a drop-in replacement, or will changes be required?
Hi @Mike_Fisher . I see you have not received an answer so let me answer some of your questions. Yes, the model number you have identified has indeed been discontinued; the PrimeCare model you’ve also identified is probably the closest replacement. Weather or not the latter is a “drop-in replacement” or not probably depends on how the first one was configured. We have not sold any of the newer Mini PRM models and have not tried to upload a config file from one of the Mini’s predecessors so I don’t know if it would work. My guess is it would not but I’ll be pleased to be corrected on that if someone else has had experience with this. -Rick
