Max BR1 mini not booting
I have a Max BR1 mini that is not booting.
The red light comes on when power is applied and stays on. In addition there is a green flash of the LED’s in Cellular and both LAN ports about once every 10-11 seconds. I can also see a constant orange light coming from inside the unit.
Tried the reset button with no effect.
Anyone have any ideas if this can be fixed?
Change your power supply. If that doesn’t help it sounds like its toast…
