I bought the MAX BR1 Mini and just learning about the failure software license in order to use the WAN for a wired connection, the license costs about $350 so i was wondering if there is any other way i can set up a wired connection as a router using a bridge without having to activate the WAN? (no sim, usb modem, this would just be for ethernet connection) this is for personal use & kind of out of my budget, i would only need to use the license once, is there a way i can purchase a 1 use license only for 1 port?
The permanent failover license costs $100 and it can be purchased from the online store:
http://store.peplink.com/software-add-ons/others/pepwave-failover-license-software-add-on.html
