we have hundreds of Max BR1 mini with cellular connections connected to different panels in different sites. The panels should report to some software. we are trying to have all panels report to our software using VPN tunnels. If I connect all devices to the FusionHub and had a VPN between our software and FushionHub, can I get all panels report to our software? we usually use Max BR1 default subnet 192.168.50.0/24. Is this going to cause an IP overlapping problem? do I need to set each panel with a different private IP?
You can use nat on your tunnel. We are a peplink partner and can help your architect this.
As Jonathan says. You’ll want to use virtual network mapping so your remote subnets stay the same but you can provide unique virtual NAT addresses access each one specifically.
