I wanted to know if anyone knew if the MAX-BR1-LTE-V-T was compatible with any other carrier located in the US? I was reading in the knowledge base about redundant SIM cards and saw option #2, which sparked the question.
- Installing SIMs from two carriers
If the signal from one carrier fails, the device can automatically connect to an alternate carrier using the second installed SIM. - Installing two SIMs with independent monthly data allowances (Coming Soon
)If the cellular account associated with one installed SIM reaches its data allowance, the device can automatically switch to a second installed SIM associated with a separate data plan, helping you avoid expensive data overages.
http://www.peplink.com/knowledgebase/max-redundant-sim-slots/
WFF
