When you need absolutely reliable connectivity, in an outdoor deployment, the new MAX BR1 IP67 has you covered! The device’s compact, super-duty IP67 enclosure makes it the ideal cellular router when things like lightning, water, or dust are primary concerns. The outdoor applications don’t stop at just industrial or mobile applications, as the MAX BR1 IP67 allows you to place the device outside, to maximize cellular connection, while connecting to your indoor hardware via simple PoE!
Your connection is also safe from any other interruptions thanks to Peplink’s SpeedFusion, allowing for hot failover between Wi-Fi and cellular connections, as well redundant SIM slots to keep your cellular connection up and running! Or use two different carriers’ SIM cards and the MAX BR1 IP67 will choose the one with the best coverage!
The MAX BR1 IP67 is also ideal for mobile and fleet deployments as well, with built-in GPS fleet tracking and InControl 2 cloud-based management!
