Are the USB-modem compatibility lists for currently supported products (e.g. MAX 700 and MAX OTG) also valid for older products such as the MAX 600?
(Was considering an upgrade to a newer LTE modem (Netgear Aircard 340U, 754S, or 779S) that is on the list, but I’m not sure if the list also applies to legacy products.)
Is there a modem compatibility list for the MAX 600? I’ve looked high and low and can’t seem to dredge one up anywhere. I guess mainly I’m curious about the Netgear Aircard 340U, 754S, or 779S.
As mentioned by Tim, the modem compatibility list does not apply to legacy products. I suggest refreshing your hardware. Else you may give a try the modems with Max600, Aircard 340U may work since it was an older USB modem.
I think I understand the part about the current modem compatibility list–the MAX 600 is a legacy product so it won’t follow the most recent compatibility list. But surely somewhere in the Peplink archives, there must be a list (document or something) that lists the modem comptabilities for the MAX 600 (back in the day when the MAX 600 was the most current model). I hate to try-and-buy several modems in order to find one that works (especially if Peplink has a list somewhere; I’ve looked, but I can’t find one).
