Marge Between ADSL and LasedLine
Hello All,
How can I marge between ADSL and LasedLine on Peplink 380? Configuration Plz?!!
Plug them into the WAN ports and you’ll get weight load balancing out of the box.
Further configuration will depend on exactly how you want to use them in combination.
-we did but lased line working fine,ADSL Appear as connected on peplink but no traffic
-We need configuration for load Balancing between to this line"Adsl&LasedLine"
What rules do you have set in outbound polices?
Did you set the correct upload / download speeds in WAN connection settings for both the leased line and the ADSL?
