Make Lan Speed Fusion Layer2 incontrol config
Hello how can I configure l2vpn
Direct incontrol with 2 peplink or pepwave
I need one subnet both side 192.168.50.0/24
Hi @amospo,
I don’t think this is possible, using InControl. If you need to configure this, via InControl, then perhaps you could use the Virtual Network Mapping option, introduced with Firmware 7.1.0
  • please note, this is technically a L3 VPN, but both sides can have 192.168.50.0/24 networks.
Here is a > Link < to a video to show how this is configured using InControl for the PepVPN / SpeedFusion setup.
Hope this helps,
Steve
Hello Steve
Could you tell me please how can I connect Layer 2 vpn between PepLink and PepWave
without Incontrol
I made a video here a while ago doing that.
Hello Martin
Thank you So Much your video was so helpful and help me with my configuration
Now I just need one more thing
as We’ve discussed I need to connect my IP Phone that connected to pepwve (WiFi) to call Manager (connected with peplink) through Pep VPN without being able to reach the internet
and create other SSID for connecting other devices with ability to use internet
thank you
Not convinced we’ve had a chat yet…
How will the wifi call work? What app are you using? Most wifi calling apps need internet access for call signalling - and most will send the call audio via their servers to facilitate calls over NAT…
Hello Martin
I mean I’ve put a post before and you answer it
Please if you could check this diagram of my topology that I want to make
this suppose explain my need
Do you really need to block internet access on the phone?
With the VoIP account set to the LAN IP of the SIP server the VoiP traffic will all go over the VPN.
If you want to block internet access I would use an enforced outbound policy on the Transit to send all traffic from the VoIP handset to the remote peplink. Then on the remote peplink I would add an outbound firewall rule to block the VoIP handset IP.
Hello Martin
Sorry I did not understand this part
However let me explain requirement
Now I have 2 wifi SSIDs
I need to connect wireless IP Phone to SSID 1 through VPN and connecting to IPBX on other side (peplink) without reaching to internet (Block Phone to access to internet, just access to von)
and connecting other devices (Smart Phones) to SSID 2 with reaching internet without ability to access to vpn (IPBX)
and Peplink should be not reached for internet (not accessible from anyone through internet)
just accessible by vpn
Thank you
